Bench bled master cylinder and bled the brakes pedal still goes to the floor.
108,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
BECKYNKEN17
  • 5 POSTS
Changed master cylinder, replaced brake lines. Bench bled master cylinder and bled the brakes pedal still goes to the floor.
Sep 5, 2021 at 9:03 AM
  • 110,248 POSTS
If you bench-bled the new master cylinder and all wheels, chances are air got into the ABS module. What you likely need to do is perform an automated bleed. You will need a scan tool that can perform this procedure.
I attached the directions below. The first part explains to do what you have already done, bleed the brakes. The second part is the automated bleed procedure.
Take a look through this and let me know if you have other questions.
See pic below.
Sep 5, 2021 at 12:57 PM
BECKYNKEN17
  • 5 POSTS
I already bought two scanners and both said they were capable of doing the auto bleed. I am not going to be buying another one!!! Next!
Sep 5, 2021 at 2:39 PM
  • 110,248 POSTS
I'm not sure I understand. Are you able to return them?
Sep 6, 2021 at 11:47 AM
BECKYNKEN17
  • 5 POSTS
The point is I am not doing it with a scan tool. I will find a way to bypass the ABS if that is the case.
Sep 6, 2021 at 12:55 PM
  • 110,248 POSTS
I understand. Let me know if I can help in any way.
Sep 6, 2021 at 2:20 PM
