Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Sable
Emission
PCV
Location
PCV valve location for replacement
2001 MERCURY SABLE
130,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
BILL BEBAWI
MEMBER
1 POST
Trying to locate the PCV valve to replace it with a new one.
Sep 21, 2020 at 8:21 AM
Experienced Mechanic
I assume you have the 3.0L DOHC and not the SOHC. The DOHC location is a little more buried then the SOHC motor.
I attached both processes depending on what you have. The last two pages are the SOHC. The prior are for the DOHC.
Images (Click to enlarge)
Sep 21, 2020 at 8:34 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
