PCV valve location
95,000 MILES
BECKFORDWALKER
I need to change the PCV valve on my car, unfortunately I'm not able to find it. I am not a pro.
Mar 17, 2016 at 5:15 AM
HMAC300
  • 48,601 POSTS
The PCV valve is located in the valve cover. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Mar 17, 2016 at 9:26 AM
BIOCHM98
Where is the PCV valve located on a 3.0L V6?
Feb 5, 2019 at 10:13 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_458.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_228.jpg
JOYFUL0022
Where is the PCV Valve located?
MERLIN2021
  • 17,250 POSTS
Top middle of the engine towards the firewall.
APRILMERIWETHER
The check engine light came on then it started shaking and cutting off at stops. Finaly it would not budge when gas was mashed. It always cranked backup and still does. I notice that the hose was hissinv when I crunk it. The hose is dry rotted and has a hole. Will replacing it correct the problem and get my car moving again?
  • 31,937 POSTS
I doubt that this will be the sole cause of your problem, but it should be replaced and then further investigations can find the problem, this hose will affect engine performance so replace and get a scan done for any unresolved fault codes, start here.
BRAVESTAR1
  • 234 POSTS
If you still haven't resolved this issue, do replace all six of your spark plug wires. I was having the same issue on a 1998 DOHC Sable, and replacing the wires stopped an issue similar, where stopping at the toll gate caused the car to shut ofrf, then restart pretty easily.
