How to replace the PCV valve?
110,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
ANGEL0324
  • 26 POSTS
PCV valve replacement.
May 19, 2022 at 10:04 AM
  • 110,248 POSTS
To replace the PCV valve on this vehicle, you need to first remove the intake manifold. Normally, it's a five-minute job, but not on this vehicle.
If you look at the first three pics below, they explain the actual removal and replacement of the valve. Pic 4 shows the location of the valve with the intake removed.
The remaining pics are the procedures for removing and replacing the intake.
May 19, 2022 at 1:42 PM
ANGEL0324
  • 26 POSTS
Okay, i don't think this is something i can deal with so i think i will take it to the dealer. thank you for your help.
May 19, 2022 at 1:51 PM
  • 110,248 POSTS
It really isn't as difficult as it appears. However, I understand if you feel uncomfortable. Regardless, if possible, let me know how things turn out for you.
Also, if you change your mind, let me know what I can do to help.
May 20, 2022 at 1:46 PM
