Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Avenger
Emission
PCV
Location
PCV valve location
2008 DODGE AVENGER
75,000 MILES • 3.5L • 6 CYL • 4WD
STEVEN AUSTIN
MEMBER
1 POST
Please help. where is the PCV valve located on this engine? I can’t find it!
Jul 3, 2019 at 8:49 AM
Experienced Mechanic
Good evening,
The PCV is on the valve cover. It is screwed into the valve cover.
I attached a picture and the procedure for you.
1. Remove positive crankcase ventilation (PCV) hose (3) from PCV valve (2).
2. Unscrew PCV valve (2) from valve cover (1).
Image (Click to enlarge)
Jul 3, 2019 at 9:12 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
