PCV locations and replacement steps needed?
80,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
SAM1948
minor oil leak from crank shaft.
Sep 11, 2024 at 10:35 PM
  • 55,682 POSTS
So, they don't have PCV valve anymore, they have air oil separators which are located in the center of the engine under the intake manifold. They have a PCV hose which connects to the separator is all. Here is how to change it out but you might be able to clean it. Check out the images (below). Let us know if you need anything else.
Sep 12, 2024 at 2:56 AM
SAM1948
Thanks Ken for your answer; but this contribute to the rear seal leak ?
Sep 15, 2024 at 6:51 AM
  • 55,682 POSTS
O ya! That is a major complaint of this kind off problem.
Sep 15, 2024 at 7:56 AM
