Where does the PCV hose plug into back of engine
200,000 MILES
KEVIN MCCOY
  • 6 POSTS
Need to know were the PCV hose plugs into on the back side of the engine?
Oct 30, 2016 at 8:36 PM
CJ MEDEVAC
  • 11,000 POSTS
I am going to see if "Prodemand" has a diagram.
Need to know if it is a 4.6 or a 5.4?
Any other designations of your rig might help me too!
The Medic
Oct 31, 2016 at 8:33 AM
KEVIN MCCOY
  • 6 POSTS
5.4 Eddie Bauer edition.
Oct 31, 2016 at 8:53 AM
KEVIN MCCOY
  • 6 POSTS
It tees into two one goes to the intake the other goes to a angle piece of tube to the rear back side of the engine to a black boot.
Oct 31, 2016 at 9:23 AM
SATURNTECH9
  • 30,869 POSTS
They usually just go to the back of the intake manifold facing the intake manifold.Those hoses a trouble spot for those even the v10 the hoses have issues as well.
Oct 31, 2016 at 2:32 PM
KEVIN MCCOY
  • 6 POSTS
Yes, there is one that does, but there is also another one that goes to the very back of the engine block and the plug looks like a spark plug boot but hours onto a nipple some were l have a 2002 F150 5.4 I followed that one, but it ties into a hose on a tee but the 1998 is not the same fitting. I not know. I see the one that goes to the top upper intake but there is another one heading to the back?
Oct 31, 2016 at 7:30 PM
SATURNTECH9
  • 30,869 POSTS
There is a vacuum diagram you should be able to figure it out with that.
Nov 1, 2016 at 1:02 PM
KEVIN MCCOY
  • 6 POSTS
That diagram doesn't show the hoses coming off the pcv valve it looks like this (see image)
Nov 2, 2016 at 8:26 PM
SATURNTECH9
  • 30,869 POSTS
Do you have a hose missing to your EGR feedback sensor
Nov 4, 2016 at 1:00 PM
KEVIN MCCOY
  • 6 POSTS
Were does that go and what does it loo like
Nov 4, 2016 at 1:02 PM
SATURNTECH9
  • 30,869 POSTS
It looks like a map sensor with a hose going to the exhaust even.
Nov 4, 2016 at 1:06 PM
