Engine swap would PCM work with different engine code
191,770 MILES • 4.3L • V6 • 4WD • AUTOMATIC
PATW54
  • 15 POSTS
I was wondering if a PCM would work if engine code is different? I'm swapping motors on my vehicle listed above and this code is W the 8th letter, and the motor I'm putting in is X the 8th letter, and I was wondering if the PCM's. Would interchange with each other? Or do I need to buy another PCM. both have the same motor 4.3L vortec.V6
Oct 19, 2019 at 6:43 AM
Good morning,
Can you give me the number off the computer for your current engine as I will cross-reference the numbers for you?
Oct 19, 2019 at 9:29 PM
PATW54
  • 15 POSTS
You want VIN number or what?
Oct 30, 2019 at 11:00 AM
No, the numbers off the ECM.
Nov 1, 2019 at 5:07 AM
