PCM will not communicate with BCM
160,000 MILES • 4.2L • 6 CYL • TURBO
DARYLLEJEFFERSON
Could i get your opinion on this problem?
Unplug radio, thief mode engaged change key and tumbler still In theft mode. relearning procedure. will not turn fuel injectors on. will not start.
this car has been in a auto shop that i am not familiar with. It is going on the third day, still has not figure it out, said PCM not communicating. Also, he ask for $500.00 up front for his labor. in your opinion does this sound right?
May 3, 2017 at 9:00 PM
HMAC300
  • 48,601 POSTS
because you changed the key and tumbler it needs to be programmed to security any mechanic with a pro scanner can fix this, but that is only way it will start.
May 3, 2017 at 11:05 PM
HMAC300
  • 48,601 POSTS
one othe thing if the pcm doesn't communicate then it may be a can/bus problem which you'll need a pro scanner to see where the problem lies it may be the wiring or a module bad.
May 4, 2017 at 8:51 AM
