PCM wiring diagram
145,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MICKCOOK
PET not working, won't crank.
Aug 28, 2025 at 5:50 AM
MECHTRIX
  • 580 POSTS
I think you meant the p.a.t.s (passive anti theaft system) it has to do with the security system / the imobiliser not recognizing the key it seems that it has locked you out it might need to be reset also its a comon accurance when you have a weak or dead batery or if there an issue with the transponder in the key on Ford vehicles good luck.
Aug 28, 2025 at 11:07 AM
  • 55,682 POSTS
The PATS system will not make the engine fail to crank over FYI.
Sep 5, 2025 at 3:20 AM
