PCM tac wire color
150,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TOPHER4331
What wire from PCM is for the tac trying to install aftermarket tac cannot go off the coil only gives me half signal. If you know where can attach green wire for the tac please.
Nov 3, 2018 at 6:53 PM
  • 55,628 POSTS
You must get a tach that work with COP ignition systems. A regular tach will not work with your set up.
Cheers, Ken
Nov 5, 2018 at 1:10 AM
TOPHER4331
Where can I find one of those tachs?
Nov 5, 2018 at 1:15 AM
  • 55,628 POSTS
Jegs should have one, I would call them.
Nov 6, 2018 at 1:22 AM
