pcm problem maybe
168,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
JO HERR
i have a crew cab 4×4 it started running really badly. I did not have time to check it out drove it like that for a week until i could look at it. I found that the spark plug wire had burnt through and was shorting out on the engine. I put a wire i had from before on it and it ran fine for a day then started bearly running. I cannot drive it. It will still start but it wont go over 3000 rpm's its throwing MAF, crank shaft/ cam shaft sensors codes. I replaced all three still same thing. my question is could it be the PCM has shorted out?
Aug 22, 2016 at 7:51 AM
HMAC300
  • 48,601 POSTS
have it erased then run again, check battery for condition including load test as a weak battery will send false codes. also check for a vacuum leak and check fuel pressure with a gauge auto parts rent it.
Aug 22, 2016 at 8:04 AM
