PCM not communicating, pinout needed?
65,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
RAJESHKMOHANDAS
I need pinout for the vehicle listed above diesel.
Jul 17, 2023 at 12:26 PM
  • 55,711 POSTS
The first thing I would do is check the scanner in another car to see if it works, next check the fuse # 5 - 15 amp in the central fuse panel at the right end of the dashboard. This guide can help:
Here are the wiring diagrams for the ALDL connector and a guide to help you check the power and ground for the system. You may have a bad PCM.
Here is how to change the engine control module out in case you need it, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know how it goes.
Jul 18, 2023 at 4:33 AM
RAJESHKMOHANDAS
Thank you so much sir.
Jul 19, 2023 at 12:16 PM
  • 55,711 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Jul 20, 2023 at 3:49 AM
