check engine light will not turn off, Code P0601
100,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
SAMEEG FESTER
Check engine light permanently on. Error code p0601. Car reaches normal temperature then does not rev up. Cools down then drives again until temperature is reached again. Codes 1390 and 0320 also comes up.
Nov 15, 2016 at 6:39 PM
HMAC300
  • 48,601 POSTS
601 is a PCM internal failure sounds like it needs a new one. 320 is no crank reference signal 1390 is timing belt skipped a tooth have a mechanic look at this it may not necessarily be the PCM.
Nov 15, 2016 at 11:17 PM
