PCM electrical schematics
150,000 MILES • 4.2L • V6 • 2WD • MANUAL
SCRIBNERMJ
I read a post on this site that included the PCM circuit schematic for 1997 v8 with automatic transmission.
Can someone recommend a link to a schematic for the PCM circuit for a v6 4.2 with a standard transmission?
Aug 15, 2019 at 12:32 AM
BMDOUBLE
  • 1,139 POSTS
There isn't a standard or automatic powertrain controls schematic, only 1 for both. I'll give you the 7 pages that are available.
Aug 15, 2019 at 3:21 AM
SCRIBNERMJ
Thank you for that!
Here is the link that I originally found on your site: https://www.2carpros.com/questions/ford-f-150-1997-ford-f-150-blown-pcm-fuse
That one in that link specifically details for an 8 cylinder automatic transmission so I just assumed there would be different prints for a 6 cylinder standard transmission.
Between the two different prints, I should have enough to go on I presume. At least to the point where if I'm going to be able to figure it out I should have enough information.
Aug 15, 2019 at 9:29 PM
BMDOUBLE
  • 1,139 POSTS
Okay, excellent! You’re very welcome!
Aug 15, 2019 at 10:45 PM
