PCM cut wiring harness?
10 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
ROME509ER
I have a 1999 jeep Cherokee sport 4x4 4.0. Someone cut my wife's wire harness and took I think c3 plug I can't find out what wire goes on each pin. She can't go to work.
Nov 13, 2025 at 3:31 AM
AL514
  • 5,692 POSTS
Hello, Im so sorry to hear someone would do that to her vehicle. So getting right to it, the C3 looks to be a Grey color connector, and we have the pinout with the wire colors Ill post here in a few minutes for you. You have a replacement connector I assume already?
Nov 14, 2025 at 5:07 AM
AL514
  • 5,692 POSTS
These are the PCM connector pinout diagrams, I included them all in case you need to verify wire coloring on one of the other connectors. I will post the PCM wiring diagrams next,
Nov 14, 2025 at 5:30 AM
AL514
  • 5,692 POSTS
If the diagrams do not post here correctly, you can either leave your email address here or send me a private message with the email address and I will send the needed diagrams. We are making some adjustments to the site, so diagrams and pictures have not always been posting with each message.
Nov 14, 2025 at 5:33 AM
ROME509ER
Hello thanks for your time & energy . Didn't allow me to open them. My email is demons666family@gmail.com
Nov 14, 2025 at 9:09 AM
ROME509ER
Its the black connector if needed I can send the Vin on the PCM
Nov 14, 2025 at 9:34 AM
AL514
  • 5,692 POSTS
Ok sent the PCM connector diagrams, let me know you get them.
Nov 15, 2025 at 4:09 AM
AL514
  • 5,692 POSTS
I found what looks to be the correct PCM connector, I sent the diagrams and PCM wiring diagrams. I would compare the other 2 connector wiring colors to be sure they are correct. Im not sure why this vin is the same, but the connectors and wiring colors are different
Nov 15, 2025 at 9:30 AM
