pcm
10,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
GERI BIGGERS-NICHOLS
got used PCM from junkyard how do we reprogram key fob?
Apr 7, 2017 at 8:55 AM
CARADIODOC
  • 34,414 POSTS
The key fob is not related to the Engine Computer. You need a Chrysler DRB3 scanner to retrieve the four-digit PIN from the old Engine Computer. then to program it into the replacement computer.
Apr 7, 2017 at 9:20 AM
then how do you program into new PCM?
Apr 7, 2017 at 9:36 AM
CARADIODOC
  • 34,414 POSTS
The DRB3 walks you through it. You press the menu choice to read the PIN. That puts it in the scanner's memory. Remove the old computer, plug in the new one, then select the "learn" function to put the PIN into the new computer. We just did this at a friend's shop last week, also for a 2005 model.
Apr 7, 2017 at 10:07 AM
