Pats disabling injectors?
175,000 MILES • 4.6L • AUTOMATIC
LCKERXXXKITTY
Battery died, 2002 F150 4-door crew cab......door was left adjar. Unhooked recharged. Hooked back up. Now won't start. Pats code 12. And is saying with a mucar v08 scan tool that only one key is programmed. Have tried to erase all keys and reprogram two keys... Still saying only one programmed. Theft light comes on and stays lit. Won't start
Aug 6, 2026 at 9:35 PM
  • 55,721 POSTS
I noticed the question says 2001 F-150 in the heading but 2002 F-150 in the description. The exact year matters for the PATS diagnostics. Code 12 points toward a problem with the transceiver/communication side of the PATS system, rather than simply "the battery went dead and forgot the keys." I would try a hard system reboot, this video will show you how.
https://www.youtube.com/watch?v=INiDRO5A5MY
Let me know how it goes
Aug 7, 2026 at 11:18 AM
KRAKENAUTO
  • 113 POSTS
We need to know the exact year as mentioned above.
Also the keys you are trying to reprogram, are they OEM Ford branded keys or Aftermarket ones?
Aug 8, 2026 at 5:40 PM
