Stalled and will not start
125,036 MILES • 3.2L
ROBERTNACE
Bought a OBD 2 code reader. But says there is no codes on module? I checked fuses none are blown. I have a repair manual but cannot figure it out.
Jul 2, 2018 at 7:54 AM
AL514
  • 5,700 POSTS
Hello there, assuming the engine cranks over, you will have to check and see if you are getting any spark while cranking the engine over. You can buy spark tester for cheap at a local auto parts store, that is a good place to start with this issue. It is the safer way so you do not get a shock from the ignition system.
Jul 2, 2018 at 8:17 AM
RENEE L
  • 1,260 POSTS
Hello ROBERTNACE,
I am sending to you a guide from this site that features step by step instructions and pictures on “how to test for spark”.
Thank you for using 2CarPros.com and have a great rest of your day!
Renee
Admin
Jul 2, 2018 at 8:50 AM
