Pass-lock sensor
160,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
DANE DESPAW SR.
  • 75 POSTS
Sometimes car will not start. re-set the security mode and it will start. If I replace the key lock cylinder will it fix the problem, or is the pass-lock sensor a separate part? Thank you.
Nov 17, 2017 at 6:23 AM
STEVE W.
  • 15,421 POSTS
The actual sensor is part of the housing the lock cylinder goes into. Replacing just the cylinder will not help.
Nov 17, 2017 at 7:00 AM
DANE DESPAW SR.
  • 75 POSTS
Okay. Thank you...
Nov 17, 2017 at 7:08 AM
