Pass-lock three
126,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
C.ROUSE
  • 9 POSTS
I have had problems in the past with the vehicle not starting all the time, finally it would not start at all. Come to find out the plastic ring that goes around the ignition lock cylinder that has the little chip or motherboard in it had broken. so i ordered a whole new lock cylinder (which did not come with a new key) but i ordered a new pk3 key blank from another place, i had the key cut to the new cylinder and i installed the new cylinder and new plastic ring with it, but i cannot get it to start and i have tried the relearn system five or six times, but i keep getting the " starting disabled due to theft system " message from the car. do you have any ideas as to what i need to do? Thanks
Nov 1, 2017 at 5:32 AM
SATURNTECH9
  • 30,868 POSTS
The problem is the original key is chipped and you changed keys. You would have to get a chipped replacement key and have it programmed to your car.
Nov 1, 2017 at 6:51 AM
SATURNTECH9
  • 30,868 POSTS
Unless you can put your old chipped key in the ignition cylinder and turn it on then off and then put your new chipped key in within ten seconds you cannot add new keys. it would be a dealership fix it takes a scan tool and GM service stall.
Nov 1, 2017 at 6:55 AM
WRENCHTECH
  • 20,758 POSTS
According to the service information you should be able to program replacement key with the relearn procedure. Is the telltale shutting off during the procedure? Have you done the thirty minute relearn?
Nov 1, 2017 at 9:04 AM
SATURNTECH9
  • 30,868 POSTS
I looked it up on all data and with the key reader without a master key you need a scan tool and access to the GM service stall it has a chipped key. I had to do one of these on a Saturn relay van the same as a Chevrolet Uplander van. no fun when all keys were lost.
Nov 1, 2017 at 11:56 AM
WRENCHTECH
  • 20,758 POSTS
Taken from Alldata.
Replacing keys:
When the correct number of learned master keys are not available to perform adding keys procedure the ten minute re-learn procedure or thirty minute re-learn procedure must be performed. Refer to programming theft deterrent system components.
The scan tool appears to only be used if replacing the BCM.
Nov 1, 2017 at 12:02 PM
SATURNTECH9
  • 30,868 POSTS
He said the oringal key no longer turns the ignition cylinder only the new key? Unless I miss understood what he posted?
Nov 1, 2017 at 12:44 PM
SATURNTECH9
  • 30,868 POSTS
That would mean your in all keys are lost situation meaning scan tool and service stall.
Nov 1, 2017 at 12:46 PM
WRENCHTECH
  • 20,758 POSTS
Master key is not required according to what i read.
SATURNTECH9
  • 30,868 POSTS
When the correct number of master keys are not available then refer to programming theft deterrent system components.
Nov 1, 2017 at 12:50 PM
SATURNTECH9
  • 30,868 POSTS
Click that link and it says scan tool and service stall .
Nov 1, 2017 at 12:51 PM
WRENCHTECH
  • 20,758 POSTS
Nov 1, 2017 at 12:55 PM
C.ROUSE
  • 9 POSTS
Thanks for all the Information guys. When i ordered the new ignition lock cylinder and new key i took the key to the dealership and they cut the key according to the VIN of the car and the new cylinder i got has the same tumblers in it as the old one so i can put the original key in the new cylinder, but it still says disabled due to security and will not start the vehicle. from what i have read the original key will not work because of the new plastic module that goes around the cylinder does not have the same signal in it as the old one (which broke) had that matches my old key. when you refer to a scan tool do you mean the ODB2 scanner?
Nov 2, 2017 at 12:53 AM
WRENCHTECH
  • 20,758 POSTS
If you cannot get the relearn to work, you will have to get an enhanced scan tool to read the security codes as there may be an additional problem in the system.
Is the relearn doing what it is supposed to with the telltale going off after ten minutes?
Nov 2, 2017 at 1:52 AM
C.ROUSE
  • 9 POSTS
No the relearn is not doing anything.
Nov 2, 2017 at 11:37 PM
  • 55,766 POSTS
It sounds like the dealership that did the programming did not do it right to me. You may have another problem like a connection issue. You should check the wiring and connection to make sure we are not chasing our tail.
(Security wiring diagram below)
Cheers, Ken
Nov 4, 2017 at 4:35 AM
