Replaced steering column now car will not stay running
125,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
DUSTIN WALKER
After changing steering column. Security light is on . car starts but shuts off after five seconds.
Oct 27, 2019 at 9:40 PM
STEVE W.
  • 15,420 POSTS
Welcome to 2CarPros. That is a common issue of an immobilizer activation. You will need to have either a well equipped shop or a dealer re-flash the transponder module in the replacement steering column so that the module is recognized and then the keys will need to be initialized as well. That would need to be done even if you replaced the ignition tumbler with the original to keep the old keys.
Oct 28, 2019 at 1:29 AM
DUSTIN WALKER
I was told the passkey antenna can only be programmed one time to one car .
Nov 21, 2019 at 7:28 PM
STEVE W.
  • 15,420 POSTS
Not that I'm aware of. You do need a scan tool to initiate the programming but I don't know of a limit on the module. Don't see anything warning about it in the service information either.
Nov 22, 2019 at 1:20 AM
