Engine starts but shuts off after three minutes
20,001 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MONTEZE
  • 6 POSTS
Car starts and shuts after three minutes. Passkey 3?
Nov 25, 2017 at 12:13 AM
STEVE W.
  • 15,420 POSTS
That is not the passkey system. Passkey would only let it run two to three seconds. Start and run three minutes or so sounds like a fuel pump issue.
Nov 25, 2017 at 1:38 AM
MONTEZE
  • 6 POSTS
So how can i fix the passkey 3. i have change the fuel pump.
Nov 25, 2017 at 1:43 AM
STEVE W.
  • 15,420 POSTS
What does the security light do? Is it on when you try to start the car? Does it come on after the engine starts? The way that system works it will at best let the engine run for a couple seconds because it only runs the pump prime signal. If the system sees the wrong key or there is another problem the PCM is sent a fuel pump disable signal and the pump does not turn on, that means 99% of the time the engine will not even start.
What is the starting and running fuel pressure? What other problems are you having?
What do you have for scan tools or diagnostic equipment?
Nov 25, 2017 at 9:01 AM
MONTEZE
  • 6 POSTS
The just turns over. It will start up and shut off after two to three seconds. The security light just comes on when I get in the car but it goes out and the fuel pressure is 145. I am stuck I need some help. Thanks
Nov 25, 2017 at 10:40 PM
STEVE W.
  • 15,420 POSTS
145 PSI or kPa? If psi you are way too high. 53-55 is normal. if kPa you are far too low in pressure, 372-375 kPa is normal.
Both ways will not allow it to run.
If you put the key in and turn it to the start position does the security light stay on while the engine turns over or does it go out?
Nov 26, 2017 at 3:11 AM
MONTEZE
  • 6 POSTS
Yes, the security light goes out when I try to start the car. I do not know if this will help you, but the battery will not stay charged at all. But, the security light do blinks when I get in the car and when I start the car it just cuts off.
Nov 26, 2017 at 3:36 AM
STEVE W.
  • 15,420 POSTS
Okay, if the light blinks and goes off when you try to start the engine the system is reading the key and recognizing it. So it isn't the pass-lock system.
If the light was staying on then it would be the passlock system.
Battery drained could be the root problem. If you have a bad battery and possibly a bad alternator it may be sending AC into the control system as soon as it starts spinning up and it scrambles the PCM.
Nov 26, 2017 at 6:30 AM
MONTEZE
  • 6 POSTS
Okay, i do understand what you are saying. So what do i need to do?
Nov 26, 2017 at 11:41 PM
  • 55,781 POSTS
You are losing spark or fuel when the engine stops running we need to see which.
Here are three guides designed to help us see which system is failing if the security light is not flashing chances are it is not a security issue.
If no spark is observed it sounds like a crankshaft angle sensor is going out.
This guide will give you an idea of what you are in for when doing he job.
This guide may help as well
Please let us know what you find out.
Cheers, Ken
Nov 29, 2017 at 4:22 AM
MONTEZE
  • 6 POSTS
Ok thank you thats what it was
Nov 30, 2017 at 2:56 AM
STEVE W.
  • 15,420 POSTS
Which one? Crank sensor or??
Nov 30, 2017 at 4:09 AM
  • 55,781 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Nov 30, 2017 at 4:10 AM
