Passing smog
2002 PONTIAC GRAND PRIX
135,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ALEXTTT
  • 59 POSTS
So I recently replace my battery and I need to pass smog. How long do i need to drive the car to cycle it?
Feb 24, 2020 at 4:26 PM
Good evening,
You will need to drive the vehicle for about 2 hours. You need to go on a highway and 55 MPH for at least 10-15 minutes. Then increase speed and drop back down to 55. Do this several times.
You cannot touch the brakes at any time or the testing is aborted.
Do this 3 times and then check the monitors.
Feb 24, 2020 at 5:00 PM
ALEXTTT
  • 59 POSTS
I have obd evap and obd exhaust gas monitor not completed.
Feb 24, 2020 at 5:21 PM
Gas monitor? Can you post a picture of what you see? There is no gas monitor.
Feb 24, 2020 at 5:24 PM
ALEXTTT
  • 59 POSTS
Here's the photo:
Feb 24, 2020 at 5:43 PM
Okay, do the drive cycle I suggested. That should set the catalytic converter monitor.
The evap monitor will run after an 8-hour sit overnight. Start in the morning and drive it for about 5 miles and then recheck the monitor.
Feb 24, 2020 at 5:46 PM
