Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Plymouth
Neon
Body
Window
Not Working
Passenger window will not go up
2000 PLYMOUTH NEON
155,000 MILES • 0.5L • 4 CYL • FWD
TINA LAVAL
MEMBER
Cannot pull up manually either.
Aug 9, 2017 at 8:52 AM
Experienced Mechanic
It sounds like you have a switch or a window motor that has gone out. Here are some a guide that will help you get the problem fixed and give you an idea on what to do to check it.
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
and
https://www.2carpros.com/articles/electric-window-repair
Cheers, Ken
Aug 14, 2017 at 1:05 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
