passenger window will not go down
200,500 MILES
SAPHIRE1
I put a new switch same problem.
Jul 19, 2021 at 6:59 AM
SQM
  • 6,383 POSTS
Are you able to operate the window from either side? Which switch did you replace (driver or passenger side)?
When push the switch, does it make a clicking sound?
Have you checked the fuse? The power window fuse located under the rear seat.
https://youtu.be/Hlna_kUt7As
If you are getting power to the switch but unable to operate the window from either side then you might have a faulty window motor.
You might find these articles helpful:
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
https://www.2carpros.com/articles/electric-window-repair
I have also attached the wiring diagram for the power window.
Let me know of any questions.
Jul 19, 2021 at 7:22 AM
