Passenger side taillight assembly issue?
100,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MTYLERSHAW
A brake light bulb went out and I bought the one according to my Manuel. When I tried installing it, I realized it didn’t have the correct base and wouldn’t fit. so, I looked on the internet and found what they say was an alternate bulb. When I plugged that into the socket, I heard a snap and the whole taillight assembly went dark. With the exception of the brake light, the rest of the bulbs still work as I tried them on the other side but nothing works on this side. Did I blow the whole assembly or something worse?
Jul 25, 2022 at 7:15 AM
  • 110,248 POSTS
Chances are the fuse failed for the right parking lamps. The brake light gets power from a different source.
If you look below, I highlighted the relevant info on the wiring schematic. Let's start by testing fuse 26 in the under-hood fuse box.
If you look at pic 2, I highlighted the fuse in the fuse box. In addition to checking the fuse, confirm there is power to and from it.
Let me know what you find.
Jul 25, 2022 at 2:03 PM
