Passenger side rear wheel locked up
150,000 MILES • 5.6L • V8 • 2WD • AUTOMATIC
RON1854
Changed emergency brake cables and brake shoes and wheel still locked up. Wondering if it has a anti slip rear end and if just one side of it can lock up if there's a problem with it ???? Ron ???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
Jan 27, 2014 at 11:02 PM
HMAC300
  • 48,601 POSTS
take the drum off if it still is locked up it's a problem inside rear end or a bearing frozen up. if not then either the parking brake lever isn't on right or you forgot to put the adjuster all the way back.
Jan 27, 2014 at 11:06 PM
