Passenger side rear brake caliber sticks
138,000 MILES
RNUSBAUM
The rear brake sticks to the point where it's hard to turn manually. The rotor and hub gets too hot to touch. I have retracted the caliber piston and with the emergency brake off I pump the brake. The brake still sticks. Do I need to replace the brake caliber?
May 11, 2013 at 12:12 AM
WRENCHTECH
  • 20,760 POSTS
Could be the caliper, could be the flex brake hose, could be frozen slides.
When it's frozen try opening the bleeder and see if it releases. If so, replace the flex hose.
May 11, 2013 at 1:15 AM
EXOVCDS
  • 1,882 POSTS
Are you sure the brake cable is releasing correctly?
Thomas
May 17, 2013 at 12:23 AM
RNUSBAUM
I think so. If I rember correctly, the brake cable is a little loose at the caliber when the brake is off. I will double check that when I can. I am currently recovering from surgery and haven't been able to test any of the suggestions. As soon as I can, I will post my results. Thanks.
May 21, 2013 at 1:02 AM
RNUSBAUM
I replaced the entire brake caliber and the problem went away.
Jul 7, 2013 at 1:03 AM
