Air conditioner fan issue
180,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
JORDANBALL341
My car has two cooling fans. The driver side is bigger. When I turn my air conditioner on the passenger side fan does not go on and the driver side runs on maximum speed. It has never done this before. I also notice the cooling does not work like it did before, but still manage to cool but longer. I think the driver side fan is picking up slack working twice as hard and I fear it my damage it.
Jul 6, 2016 at 8:15 AM
WRENCHTECH
  • 20,760 POSTS
You could be right. Someone has to follow a wiring diagram to determine if and where there may be a problem.
Jul 6, 2016 at 8:28 AM
JORDANBALL341
Any possible reason why?
Jul 6, 2016 at 8:38 AM
WRENCHTECH
  • 20,760 POSTS
There are a dozen different possible causes. Bad motor, bad wiring, bad relay, bad computer, bad pressure sensor, etc.
Jul 6, 2016 at 8:41 AM
