passenger seat fuse keeps blowing?
2016 BMW X1
102,000 MILES • 4 CYL • TURBO • 4WD • AUTOMATIC
DIVIDES
  • 903 POSTS
I replaced it and I moved the front and back portion and all was good. next day I came to checkout and it stopped working. I need to know if there is anything else besides the seat on that fuse
Nov 18, 2025 at 8:37 AM
  • 55,065 POSTS
So that would be fuse #95 and there is no other power draw on this fuse, it is for the seat power only. Let us know if you need anything else.
Nov 19, 2025 at 1:44 AM
DIVIDES
  • 903 POSTS
Ya I think that is the one I replaced. what would cause it o blow again then if the seat motors work like they should
Nov 19, 2025 at 1:45 AM
  • 55,065 POSTS
It must be a seat motor that is going bad and pulling too many amps or the seat track is jammed, did you try WD40 on the tracks? I would use a volt meter that has an amp attachment on the power wire to the seats to help confirm the issue. Here is one from Amazon for $24.00
https://amzn.to/4oQSkzr
Let us know what you find.
Nov 19, 2025 at 2:02 AM
