passenger read door doesn't always lock / unliock when the rest of the car does
119,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
SC_STUBBS
The passenger rear door some times does not lock. Is there an adjustment inside the door to correct this?
Jun 24, 2015 at 12:25 PM
SATURNTECH9
  • 30,868 POSTS
So when using the power door locks this happens ?Not when locking and unlocking it manually? If so you could have a failing door lock actuator.
Jun 24, 2015 at 3:20 PM
SC_STUBBS
No issues with manually locking the door. When I use the automatic door lock feature one of the back doors locks sometimes but not all the time. Is a failing actuator the only possibility? Is replacing the actuator something I could do? What do I need to do to get the door panel off? What do I need to know to change out the actuator? I have changed them in other cars, but this car is new to me.
Jul 2, 2015 at 3:37 PM
