Passenger power sliding door not functioning
90,000 MILES • 6 CYL • FWD • AUTOMATIC
STRATOSTAN
Hello. I replaced my passenger side sliding door lock actuator, the power door worked before I did this. I found I had issues with the manual handle after I got the lock to work. While trying to fix this issue, I think I screwed up something in the door. The power lock does not work now even with the new actuator and the power sliding door stopped working. I have checked the wiring harness and could not locate a break, is there anything else I can try? I also removed the fuse that I had seen refenced for 15 minutes to reset the computer, that did not do it. The driver's side works so I don't think it is the fuse. Is there another fuse in line by the door? Please help. Thank you
Jul 13, 2014 at 12:42 PM
  • 110,251 POSTS
Have you checked to see if there is power to the actuator?
Jul 13, 2014 at 1:01 PM
STRATOSTAN
How would I check that? It did work and then stopped after I had the issue with the door closing and kind of freezing up.
Jul 13, 2014 at 10:30 PM
  • 110,251 POSTS
Just actuate the solenoid and check to see if there is power to it when you do that. You can use a test light or a multimeter
Jul 14, 2014 at 12:14 PM
