Passenger low beam not working
72,000 MILES • 2WD • AUTOMATIC
VWTIGUAN2012
My passenger low beam will not work. I’ve replaced the bulb and nothing. I want to check fuses but there is no fuse book to show me what is what. Does anyone know which fuse to check or how a can solve my problem. I also switched sockets to make sure it wasn’t that and the passenger one works in the driver side so it’s not the socket.
Sep 16, 2019 at 7:28 AM
94 TRANSAM
  • 680 POSTS
Hi and welcome to 2CarPros.
It sounds like the ground for that headlight may be bad.
I would test the socket for a good ground and then trace the wire back to where it bolts to the body and clean that.
Here are some instructions on how to test it with a multi-meter and a test light:
Let us know if you need more help.
Rich.
Sep 16, 2019 at 10:23 AM
