passenger front turn signal wont work
130,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
CPERZYNSKI
  • 5 POSTS
New module in place. new headlight new bulbs. turn signal will not work. no kinks in wiring. my husband auto mechanic. When my husband takes wires apart in front and uses tool to check wiring it flashes fine. Why wont they work when hooked up
Jun 30, 2015 at 8:46 AM
LOU P
  • 118 POSTS
Most often the issue is the turn signal switch in the steering column , did the signals work before the "module" was replaced ? And what "module " was it ?
Jun 30, 2015 at 9:36 AM
CPERZYNSKI
  • 5 POSTS
The back turn signal works just not the front. So steering column not the problem. Its throwing us for a loop.
Jun 30, 2015 at 10:53 AM
CPERZYNSKI
  • 5 POSTS
no the turn signal did not work before it so we replaced it twice with two new modules
Jun 30, 2015 at 10:54 AM
LOU P
  • 118 POSTS
Ok you still have. It told me what you mean by "module" ?
Jun 30, 2015 at 11:14 AM
CPERZYNSKI
  • 5 POSTS
took car into buick dealer they put in a new module for front light. the only thing we have nott done is see if filament has been reversed
Jun 30, 2015 at 11:36 AM
CPERZYNSKI
  • 5 POSTS
the drivers side works fine
Jun 30, 2015 at 11:37 AM
