Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Peugeot
307
Body
Door
Symptoms
Open
passenger door cannot open from inside or outside
2002 PEUGEOT 307
187,000 MILES • 2.0L • 4 CYL • 4WD • MANUAL
JAZZM73
MEMBER
When I use the remote control,I can hear the catch unlocking ,the will not open
May 24, 2014 at 8:03 PM
Experienced Mechanic
Is it the door that will no open? If you unlock it by hand, can you open the door?
May 25, 2014 at 9:30 AM
JAZZM73
MEMBER
The door remains shut at all times.But when I use the fob or try to open the door from outside or inside of car ,nothing happens
May 25, 2014 at 4:53 PM
The inside door panel needs removed to see if the linkage has broken or come disconnected.
May 26, 2014 at 9:53 PM
JAZZM73
MEMBER
How can I remove the inner door panel when door is locked .All catches and screws are on edge of the door?
May 29, 2014 at 5:32 AM
I have always had to work at accessing them. At this point, that is all you can do. We need to get inside to check what has happened.
May 29, 2014 at 12:03 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
