passenger door cannot open from inside or outside
187,000 MILES • 2.0L • 4 CYL • 4WD • MANUAL
JAZZM73
When I use the remote control,I can hear the catch unlocking ,the will not open
May 24, 2014 at 8:03 PM
  • 110,248 POSTS
Is it the door that will no open? If you unlock it by hand, can you open the door?
May 25, 2014 at 9:30 AM
JAZZM73
The door remains shut at all times.But when I use the fob or try to open the door from outside or inside of car ,nothing happens
May 25, 2014 at 4:53 PM
  • 110,248 POSTS
The inside door panel needs removed to see if the linkage has broken or come disconnected.
May 26, 2014 at 9:53 PM
JAZZM73
How can I remove the inner door panel when door is locked .All catches and screws are on edge of the door?
May 29, 2014 at 5:32 AM
  • 110,248 POSTS
I have always had to work at accessing them. At this point, that is all you can do. We need to get inside to check what has happened.
May 29, 2014 at 12:03 PM
