While driving the passenger Airbag Light warning light and chime turns on the dash
104,000 MILES • 4.6L • V6 • 4WD • AUTOMATIC
RJSPILL
I keep getting a passenger air bag warning light and chime on the dash while driving. It is at random times and will intermittently go off whether there is a passenger in the seat or not. I and I checked to make sure everything was plugged in all the way under the passenger seat.
May 11, 2022 at 5:49 AM
  • 55,721 POSTS
This happens when the seat bottom gets wet and starts to sag triggering the occupant detection sensor in the cushion, or the occupant detection sensor is going bad, try to connect the seat belt even though no one is in the seat to see if that makes the warning go away. Here is the location of the sensor so you can check it out or replace it. Let's run the codes to see if any come up. This video will show you how. Also, I have included the airbag wiring diagrams so you can see how the system works (below).
https://youtu.be/gnSGfEqrf_w
May 12, 2022 at 2:49 AM
