Passcode, cluster
89,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
RMT6319
My car will turn over, immediately stops. Leaving the key in the on position for some time removes the security light and it starts normally but will do this again shortly after. The panel needles do occasionally stop, shake, then resume functionality.
Oct 10, 2018 at 4:54 AM
STEVE W.
  • 15,409 POSTS
Welcome to 2CarPros The descriptions sounds like a typical cluster failure. The passcode data is stored in the cluster and the re-learn that you are doing allows it to operate until the cluster fails again. Replacing the cluster and having it programmed to the vehicle would repair the problem, or there are places that can repair the the original clusters as well, simply look online for a place close to you that does the repairs. That allows you to keep the original units and once the re-learn is completed as you already know that process it should not forget again.
Oct 11, 2018 at 8:28 AM
