pass. door switch/ driver side windsow switch
70,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
ZELLERDEREK4
  • 63 POSTS
i got 2 problems pissin me the f*** off and i need some answers seeing how im broke as sh*t right now i am excellent at rebuilding electrical parts but wanna no if its possible or if there is another problem passenger door says its open in anything 50 and below and sets off alarm can it be opened or wires crossed to make it stop if so which wires and 2 days ago my windows stopped working realized plug started to melt on 1 terminal and now interm. at working sometimes driver window switch makes buzzing sound like faulty relay ..... but is there a relay in the switch itself?
Dec 30, 2013 at 12:06 PM
ZELLERDEREK4
  • 63 POSTS
any help is much appreciated i am puzzled
Dec 30, 2013 at 12:09 PM
HMAC300
  • 48,601 POSTS
this will need to be scanned by a pro to find the one problem. there are no relays in power window but it dependson whether it is a coupe, sedan or convertible. I assumed it is a sedan. this could also be a body control module as well. so it will need scanning, auto parts cannot scan for this
Dec 30, 2013 at 10:59 PM
ZELLERDEREK4
  • 63 POSTS
is it possible to rebuild the door switch though? and thank you for the rapid response
Dec 31, 2013 at 1:55 AM
HMAC300
  • 48,601 POSTS
nope
Dec 31, 2013 at 2:31 AM
ZELLERDEREK4
  • 63 POSTS
ok now i am looking for a wire diagram for the passenger door till i can order the part do you know if it activates the door ajar warning when it makes contact or does not make contact
Dec 31, 2013 at 3:17 AM
HMAC300
  • 48,601 POSTS
there shold be a switch there that when the door is closed it takes the ground away so it won't turn the ldoor ajar light on. it cold be broken andgrounding all the time or it's a body module problem that is why it should be scanned.
Dec 31, 2013 at 3:58 AM
ZELLERDEREK4
  • 63 POSTS
ok thank you for your help and resoponses i figured it out and figured if u cut the brown wire with the white tracer that eliminates the door ajar and still allows the auto lock function to still work
Dec 31, 2013 at 3:51 PM
