location of engine control box needed
150,000 MILES • 2.0L • 4 CYL • 4WD • MANUAL
CSUDAY ANDRAS
  • 5 POSTS
Where is the engine control box located?
Apr 25, 2017 at 4:56 AM
HMAC300
  • 48,601 POSTS
see picture for location under carpet under dash. if replacing it will need to be programmed by a mechanic for security system in order to start car.
Apr 25, 2017 at 5:10 AM
CSUDAY ANDRAS
  • 5 POSTS
Thanks for the immediate explanation.
Apr 25, 2017 at 5:26 AM
CSUDAY ANDRAS
  • 5 POSTS
After changing the control box no difference. No problem with the cold motor.After warming up the motor weak, or stops, and blow up into the chimney. Try to change the injectors now
Apr 25, 2017 at 6:37 PM
HMAC300
  • 48,601 POSTS
why not you scan for codes and check fuel pressure before doing that you guys waste so much money on good parts before doing the correct things auto parts scan s for free and you can check fuel pressure although you may need an adapter. auto parts rent the gauge. See link.
Apr 25, 2017 at 11:26 PM
CSUDAY ANDRAS
  • 5 POSTS
After changing the control box no difference. No problem with the cold engine. After warming up the engine weak, or stops, and blow up into the chimney. Try to change the injectors now
Sportage 1996 4x4 2 l 16 w.
Apr 26, 2017 at 2:39 AM (Merged)
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure first see what is really wrong. auto parts scans for free and rent gauge see link.
CSUDAY ANDRAS
  • 5 POSTS
Code 8 The automatic air control system needed cleaning.
HMAC300
  • 48,601 POSTS
there is no code 8 it's either a p code or B code which a mechanic is going to have to get if it's an engine problem it will be a p code which auto parts can get for you then get back to us.
Apr 26, 2017 at 5:17 AM
