Code 03200, Parking brake switch, remove the rear fuse box?
141,000 MILES • 3.2L • V6 • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Parking brake light was flashing and a malfunction message, found some water around fuse box and EPB module in trunk. Removed the module and replaced it, then did an active test via scanner and I heard the calipers move, then deleted codes and it worked then stopped again, but only code I found was 03200 which is for the switch. Removed it and cleaned it and cleaned the connector worked a few times, then stopped again, ordered another. I want to remove the rear fuse box to clean it from moisture and put a fan to dry the area, any idea how to remove it?
Mar 25, 2025 at 6:47 AM
  • 55,711 POSTS
It looks like it just unbolts, I would disconnect the battery first to avoid any short circuiting. Post images if you have any issues. Check out the images (below).
Mar 27, 2025 at 2:35 AM
BHAMDOC1973
  • 2,007 POSTS
I just placed a fan on the area for 2 days, so far so good, everything works. Thanks
Mar 27, 2025 at 4:28 AM
  • 55,711 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Mar 28, 2025 at 2:06 AM
