how to detach parking brake cable
250,000 MILES • 4WD
VIRGINIA MCKENZIE RADONS
parking brake cable, how to detach cable to the lever that expands the shoes?
Jun 18, 2017 at 4:51 AM
CARADIODOC
  • 34,415 POSTS
There's a long spring wound around the cable where it attaches to the lever. That spring is what keeps the cable from falling off that lever. The easiest way to remove it is to grab it near the lever with a needle nose pliers, pull it forward, away from the lever about an inch, then squeeze the pliers to grab the cable and hold the spring there. Now you can twist the cable to pull it off the lever.
Jun 19, 2017 at 4:29 PM
