Put transmission in Park while driving?
88,455 MILES • 4 CYL • 2WD • AUTOMATIC
LEXIE LAVALLEE
I accidentally put my car in park while driving about forty to forty five mph this was just tonight. I drove about a mile after and parked it at home have not started it yet. What damage could I have done?
Aug 21, 2018 at 1:44 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Well, if you would have done major damage you would not have been able to get home or it would have shut off right there on the spot. Have you noticed any transmission fluid on the ground where parked? Give it a try and let us know! Hope this helps and thanks for using 2CarPros. We look forward to hearing back with a status report.
Danny-
Aug 22, 2018 at 10:26 AM
LEXIE LAVALLEE
I do not see any transmission fluid on the ground, but I am more concerned about what minor damage could have been done. It does not seem to be slipping or anything like that. Gears change fine, car still holds in park on hills.
Aug 22, 2018 at 1:41 PM
DANNY L
  • 5,648 POSTS
Hello again.
Consider it lucky. I do not believe you did any damage then. You will know within fifty miles or so of driving if the TCM (Transmission Control Module) will turn the Check Engine Light on. Hope this helps and thanks again for using 2CarPros.
Danny-
Aug 22, 2018 at 1:48 PM
LEXIE LAVALLEE
I definitely drove over fifty miles today and no check engine light. Thank you.
Aug 22, 2018 at 2:12 PM
DANNY L
  • 5,648 POSTS
You are welcome!
Thanks again for using 2Carpros.
Danny-
Aug 22, 2018 at 4:06 PM
