Park lights will not turn off?
238,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
EDWARD ELLIOTT
Park lights won't turn off by the switch or when you pull the fuse.
Jul 13, 2022 at 9:27 AM
  • 55,851 POSTS
This means someone has wired power to the parking light circuit, here is the parking light wiring diagrams so you can see how the system works which is pretty basic, there are no relays that can stick on causing the issue. Here is a guide to help you check the wiring:
Jul 14, 2022 at 6:30 AM
