park lights and side marker lights
1980 CADILLAC ELDORADO
73,000 MILES • 6.0L • V8 • FWD • AUTOMATIC
WRIGHT10CALVIN
My park lights and side marker lights will not turn off. I have turned them off at the headlight switch and even disconnected the head light switch nether solve the problem i still have the headlight switch out and i dont know what else to do.
Jan 29, 2014 at 2:10 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
find the fuse for the lights by unplugging them one at a time and watching for when the lights go out. when they do plug it back in and see if they come back on. if they do you've probably got some wires that are shorted to ground possibly through one of the light sockets. take all the lights that are on and take the bulbs out one at a time like you would Christmas tree lights. take note of the condition of the sockets. are the bulbs stuck in ther from corrosion or doe anything look overheated or burned. also follow as much of the light switch wires as you can see to check for cracks or frays. do the same with the socket wires
Jan 29, 2014 at 2:43 AM
