Park Avenue rear defrost not work
285,000 MILES • 3.8L • 6 CYL • TURBO • FWD • AUTOMATIC
RKWOODY
  • 6 POSTS
I replied to another thread on my issue but will also ask the question separately.
I am still having issues with my '99 PA rear defrost. I have replaced antenna module and have power all the way across the grid but it still won't work. (In face my rear glass was just replaced due to a crack so I know the grid is fine) I stopped in my local GM garage and talked to service tech Bob (who is 67 yrs. Old and has been working on cars since he was 12!) Who had originally diagnosed problem as faulty module. When I explained that I tested the grid he asked if the grids tested the same all the way across. As you move further from the electrical source. I told him that my test light was equally bright all the way across, top to bottom. He said if that is the case I then have a ground problem because the light should get dimmer as you test and move further from the electric source. I'm not an EE so I wasn't sure what to make of this. Bob said I need to check the ground for the grid but I don't know where that is. I'm perplexed - I now I have power, the back window is brand new and the antenna module if fine. Any insights would be GREATLY appreciated - thanks in advance!
AD
Reply
Dec 12, 2014 at 10:14 PM
WRENCHTECH
  • 20,758 POSTS
Sounds like he may be correct. Any circuit requires a complete circuit of both power and ground and can't operate without both.You have 2 wires attached to the grid. One is power and one is ground.
This circuit grounds through the radio antenna module coil
Dec 12, 2014 at 11:50 PM
WRENCHTECH
  • 20,758 POSTS
This is the antenna module coil https://www.2carpros.com/images/external/79033092.gif REMOVAL PROCEDURE Remove the right sail panel trim. Disconnect the body harness from the module. Remove the bolt (2). Disengage the tab on the module (1) from the slot in the sail panel. INSTALLATION PROCEDURE Engage the module tab in the slot. Align the module hole for the bolt (2). Rotate downward the module (1). NOTE: Refer to Fastener Notice in Cautions and Notices. Install the bolt (2) for the antenna ground coil module. Tighten Tighten the bolt to 7.5 N.m (66 lb in) .
Dec 12, 2014 at 11:57 PM
RKWOODY
  • 6 POSTS
Interesting that I actually pulled that small module off yesterday. Would you replace it or try to repair it? I've never seen them go bad from discussions I've read in various forums. Have you seen these go bad with other folks? I may order anyway - cheap part; less than $10.
Thank you very much for the prompt response!
Dec 13, 2014 at 12:33 AM
WRENCHTECH
  • 20,758 POSTS
We don't make repair decisions based on what we may have seen in the past. We simply, systematically test the circuit. It's a pretty basic thing to test for ground on that wire without guessing.
Dec 13, 2014 at 12:36 AM
RKWOODY
  • 6 POSTS
So would you suggest I bypass the module and ground the wire coming off the grid using another wire; and the re-test the electrical current going through the grid...to see if it decreases as you move across the grid?
thanks again
Dec 13, 2014 at 12:40 AM
