Tested for parasitic drain in circuit with negative battery cable finding 0.10 Amps. Further diagnosis finding btn#2 at battery junction box removed fuse removed brings amps to 0.00. also fuse #27 in cabin fuse box when removed also brings amperage draw to 0.00 amps. I'm showing #27 10amp fuse controls : GEM, Audio, Cluster, Interior lamp, Map lamp, Cargo lamp, . My question is, how do I find which item is causing the power drain and how to test each item in circuit? A huge thank you to all mechanics and 2CarPros and owners for your help and assistance you don't get enough praise or thanks for what you do .Thank you all! JJ
Sep 12, 2021 at 12:50 PM
