Parasitic electrical leak
2004 DODGE INTREPID
120,000 MILES • V6 • 2WD • AUTOMATIC
ANGELA GALLACHER
  • 20 POSTS
I have had this car for a few years and it does this very irritating thing where if I drive a short distance and turn off the car, there is like a 50% chance it wont start again. When it does this the car will turn over and over but just doesn't start up. And the weird part is, I only have to wait fifteen minutes and then it usually starts up. Onetime it stranded me for an hour before it started up again. My car batteries always die super early too so I'm not sure if that's part of it or not.
Apr 12, 2019 at 11:09 AM
CARADIODOC
  • 34,381 POSTS
You're describing the classic symptoms of a failing crankshaft position sensor or camshaft position sensor. This type of failure is real common on all car brands. Both sensors often fail by becoming heat-sensitive, then they work again after cooling down for about an hour.
When you're driving, natural air flow keeps the sensors cool. When you stop with a hot engine, that heat migrates up to the sensors, causing them to fail. We call that "hot soak".
The problem is the Engine Computer is able to detect when one of those sensor signals is missing, and it can set a diagnostic fault code, but that usually doesn't happen just from cranking the engine. The computer needs more time to detect the problem, as when a stalled engine is coasting to a stop. For that reason, many mechanics overlook the cause because of there being no fault code.
The solution when there's no fault code to get us started is to connect a scanner to view live data during cranking. Both sensors will be listed with a "No" or "Present" to indicate if their signals are showing up at the computer. When one stays on "No" during cranking, it is the cause of the no-start about half of the time. First we have to rule out wiring and connector terminal problems, however, based on your observation of how this acts, it's a pretty good bet it's due to the sensor itself.
The next problem is to verify this, the mechanic has to be watching the scanner while the problem is occurring. Typically that means leaving the car with him. You might try getting the engine warmed up, then stopping in his parking lot. If the problem acts up then, he is going to have to drop everything and run out right away before the sensors cool down.
Apr 12, 2019 at 12:24 PM
ANGELA GALLACHER
  • 20 POSTS
This inquiry was for my brother's car. I replaced the sensors but he sold it before I ever got confirmation that the solution worked so that I could make the report here. I'm just grateful for the advise we got in such a timely manner and written in such a way that it was easy to understand. Thank you!
Oct 21, 2019 at 2:26 PM
CARADIODOC
  • 34,381 POSTS
That's one way to solve a problem. Please come back the next time you need our great and wondrous wisdom!
Oct 21, 2019 at 4:31 PM
