Parasitic draw on 30 amp amplifier fuse (Bose)
2004 CHEVROLET AVALANCHE
60,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
BEAR53534
  • 6 POSTS
What should I Look for? Also heated seats turn themselves on and off.
Oct 23, 2018 at 5:32 AM
Good afternoon again.
I attached all the information on your seat to your previous post.
As far as the draw, how many milli amps is the draw? Did you unplug your amp and see if it went away?
https://www.2carpros.com/articles/car-battery-dead-overnight
Oct 23, 2018 at 8:56 AM
BEAR53534
  • 6 POSTS
No, the harness is in the center console. I did remove the fuse and the battery is holding up now of course the radio does not work.
Oct 23, 2018 at 9:03 AM
Okay, unplug the radio and install the fuse and see if it still happens.
Oct 23, 2018 at 9:04 AM
BEAR53534
  • 6 POSTS
I have taken the radio out and put the amplifier fuse back in and after letting everything go to sleep I am not seeing and voltage drain on the amplifier fuse. What would be the next thing to do.
Oct 26, 2018 at 8:05 AM
If the fuse is holding, turn the key on and see if the fuse fails.
if it does, then unplug the amp and retest.
if the fuse holds, the radio is the issue.
Oct 26, 2018 at 8:22 AM
BEAR53534
  • 6 POSTS
The fuses have not been failing. It was just killing the battery when the fuse was in place for the amplifier.
Oct 26, 2018 at 11:52 AM
It sounds like the radio is the draw if it stopped after removing it from the car.
Oct 27, 2018 at 11:12 AM
